Heya fellas,
Installed some cameras on a pole today (back again tomorrow to finish the other poles) and the electrician the site used installed the receptacles at the top of the poles... Which wouldn't be so bad if it weren't a GFCI receptacle on each pole at the top... Anywho. I know that for Residential occupancies do not require GFCI protection when the receptacle is installed greater than 2.5M above grade... But this is a commercial setting. The GFCI is mounted at the top of a pole that is approx. 15' tall. See image below.
Now, I was told to fix it. I told the site project manager that the GFCI protection technically isn't even needed because it's plugged into a GFCI on the generator... Well that set him off on a rant about the power and the poles and everything and I really don't care. I was told to fix it so when it trips I don't need a 12' ladder or a boom lift to reset a GFCI...
So tomorrow I am going to lower the receptacles on the poles to around the height of my enclosure to make everyone happy. But is the GFCI protection really necessary if the receptacle is mounted that high above grade? I normally only deal with resi stuff, but I thought the rule that said above a certain height didn't need it, and I was sort of right, but it's wrong because it's a resi rule that I am thinking of...
Tl;dr - GFCI required on top of 12-15' tall pole in commercial?
