1 - 17 of 17 Posts
Not sure about NEC, but the CEC requires:
4-038 Colour of Conductors
(3) Where colour coded circuits are required, the following colour coding shall be used, except in the case of service-entrance cable and insofar as Rules 4-030 , 4-032 , and 6-308 may modify these requirements:
1 phase ac or dc (2-wire) -- 1 black and 1 red or 1 black and 1 white*† (where identified conductor is required);
1 phase ac or dc (3-wire) -- 1 black, 1 red, and 1 white*†;
3 phase ac -- 1 red (phase A), 1 black (phase B), 1 blue (phase C), and 1 white* (where neutral is required)
felonious smile.
The greenfield run through that box? What is that, low voltage or. Communication?
MadDawg said:
Not sure about NEC, but the CEC requires: 4-038 Colour of Conductors (3) Where colour coded circuits are required, the following colour coding shall be used, except in the case of service-entrance cable and insofar as Rules 4-030 , 4-032 , and 6-308 may modify these requirements: 1 phase ac or dc (2-wire) -- 1 black and 1 red or 1 black and 1 white*† (where identified conductor is required); 1 phase ac or dc (3-wire) -- 1 black, 1 red, and 1 white*†; 3 phase ac -- 1 red (phase A), 1 black (phase B), 1 blue (phase C), and 1 white* (where neutral is required)
Dude it is spelled color.
Colour ? Even spell check is trying to correct you
According to the National Center for Education Statistics in about 30 years you will spell it colores :eek:
Reactions: adamv7010
1 - 17 of 17 Posts
