21 - 30 of 30 Posts
Klein's Tradesman Pro Organizer Backpack is a little cramped. I store my hammer along the bottom of my bag and am wondering if I can fit a drill inside. I most likley can but it might be a tight fit.
I had the VPP Tech Pac before, and currently use the Tech Pac LT in conjunction with my MC. The backpack is a new setup that a lot of guys are still unsure of, but once you get over that stigma, it actually makes sense. The fact that you have 2 free hands to grab more material, or the next rung on the ladder is great. Also the heavy weight of the tools isnt resting on one shoulder, rather your entire back, which is great if you have to walk long distances around the job, or just even to your truck.
Does anyone own a tool backpack? Milwaukee, Klein tools, and veto pro pac seem to be the top ones. I saw the Milwaukee and Klein at HD. Thinking about picking one up. I like the veto but I can't afford it.
The other day I stopped at a job site and saw an hvac technician wearing one. Looks like it would be a good thing if you were climbimg into an attic or any other secluded area. He had the Klein back pack.
I do service work and I love the Klien backpack. My only complaint is that it could be bigger in the middle. I have trouble zippering it closed when I have my drill, nail & small tool pouch inside.
I've been rocking the Klein BP for a couple weeks now, and am pretty happy with it. It is definitely a hand tool and meters rig though. I did squeeze my impact in the other day but normally use a separate bag for battery tools.
I like the Milwaukee ultimate jobsite backpack. I used to have Klien but went through 2 of them in two years. The zippers are the weak part. Plus they don’t have enough pouch holders for tools. Not much innovation in them either. The Milwaukee folds down all the way. It has tons of storage for tools and can easily fit drills and small fastening boxes like dewalt. They also have water bottle holders on both sides. This is a really good backpack for work on roofs doing led retrofitt or Ac matinence. And who would think a back pack is used to replace a tool belt. Tool belts are for apprentice that do production work. Most foreman and people in charge don’t wear them. They carry the small tools like cutters and strippers in there back pocket for the immediate task at hand.
Old Grumpy Bastard
I rather stick with a company that only makes backpacks and not carry one that is just one item in their inventory of a thousand.
I swear by Toolpak, they last decades and are very light.
I have a dewalt pack that rigged with my goto hand stuff plus a m12 drill/driver. as a low volt guy its been a blessing. my packout has everything else and is a great companion. If i do any manhattan service work I pack a small tool roll with barebones and throw that in a traditional travel backpack with a laptop. My dewalt bag has,
1 ratchet with 3 deep sockets (mostly for rack work, occasional other things)
1 vicegrip
1 set dikes
1 set linemans
1 set needlenose
1 11 in 1 screwdriver
1 catspaw prybar
1 wood chisel
1 set hook and pick (awl, 45 and 90 degree and hook)
2 sets wire stripper for various gauges
1 set heavy duty cable cutter
1 set flush cuts
1 punchdown tool
1 category crimper
1 coax stripper
1 coax crimper
1 coax flaring tool
1 small adjustable wrench
1 can wrench
1 security bit set
1 twisted pair continuity tester
1 tone and probe
1 lv ring template
1 jab saw
im probably forgetting some stuff but as you can see it holds a lot
Old Grumpy Bastard
1 vicegrip
1 set dikes
1 set linemans
1 set needlenose
1 catspaw prybar
1 wood chisel
1 set flush cuts
1 punchdown tool
1 category crimper
1 coax stripper
1 coax crimper
1 coax flaring tool
1 can wrench
1 security bit set
1 tone and probe
1 lv ring template
1 jab saw
Looks like a decent set up.
21 - 30 of 30 Posts
