21 - 40 of 77 Posts
Coffee drinking member
You forgot #3 - Never eat the last bite of a sandwich
I eat out of the plastic baggie.
Potato chips are fun.
Forgetting a spoon when I have pudding is always a problem.
Discussion Starter #22
Get your local inspector to put it in writing that you do not need to follow the NEC and torque circuit breakers, switches, and receptacles. Then I will listen to you. (but only in your jurisdiction.)
Also, overtightening distorts the threads and can cause loose and arcing connections.
Arsholeprentice
It's because he was tied up torquing device screws on a large house.
Look, this isn’t anything to joke about. Without proper torquing we will soon look like this..
Reactions: mofos be cray
Arsholeprentice
But I backstab all my aluminum conductors. That's because I care about children on fire.
I only backstab on #12 and above, because I consider custom receptacle modifications the core of my business model.
Reactions: samgregger
Bro... You take a long time to reply to a thread you started... last year...o_O
He has exactly two posts. On starting this thread a year ago and one replying to it. Seems odd. This is the one thing he truly cares about.
Arsholeprentice
It was probably him that introduced it to the CMP...
A sign of seasoned pro. That's why everybody runs down backstabbing, they're not pro enough to know that the existing opening are only to landmark the place where modifications can be made.
Arsholeprentice
Wise beyond your years you are.
An open end wrench?
Dam I wish I had thought of that, better then using needle nose pliers..
Band Member
DIYer Extrodinaire
Oops ! I thought the title was "Touque for Receptacles and Switches"
Carry on ..... 😜
Reactions: tmessner
Removing the screws seems to be a waste of your time. If you work your time out I do not believe the scrap value will pay for the time wasted.
21 - 40 of 77 Posts
