First let me say that I'm asking this question as I really have no other options. I'm building an off-grid cabin in the woods and there is simply no electrician to hire.
So with that said, the cabin (more like a small house) will have a mini-split for AC and heating. Due to the size (16X24) I require an 18K BTU unit to adequately heat and cool. Of course all mini-split over 12K BTU are 240V (I bet you can see where this is going). Since all my current power options are 120V I want to use a transformer to run the mini-split. Here is where my knowledge lacks.
As I understand a mini-split requires "split phase" 240V with 2 hots (L1 and L2). However many of the consumer grade transformers on the market output straight 240V like in Europe (I think). Would a mini-split run on this straight 240V that is a hot and neutral? Or would I need to rewire the transformer in a different config (as I understand it, as an autotranformer).
