1 - 9 of 9 Posts
I am trying to find out how to use a transformer to convert 1ph 208 no neutral to 1ph 240 with neutral.
Bilge Rat
motors and controls.........
Transformers are made to do just that.
Figure your load and size accordingly then get a unit with a 208 volt primary and a 120/240 volt secondary.
If for example, the load figures out to need a 5KVA unit, the Square D model would be 5S7F. It has a 208 primary and a 120/240 secondary.
Other manufacturers will have the same unit, I just happened to have my Square D book handy.
Square D has then from 1KVA up to 167KVA.
Wow, dudes. It's a transformer. 208 volt single phase primary, 240/120 secondary.
Micromind's response is spot on :thumbup:
1 - 9 of 9 Posts
