wut he sed
EMT in resi, that's pretty rare. Not really sure if your inspector would allow 2 NMD cables, could maybe use 14/3 instead?Still learning the finer points of this resi renovation chit. Can I put two 14/2 NMD's into one of those things?
No not really. This isn't the Canaduh sectionFrunkSlammer said:EMT in resi, that's pretty rare. Not really sure if your inspector would allow 2 NMD cables, could maybe use 14/3 instead?
Two furnaces, two switch legs. I'll throw in a JB.EMT in resi, that's pretty rare. Not really sure if your inspector would allow 2 NMD cables, could maybe use 14/3 instead?
I put 2 (14/2s) in a 2 screw set connector all the time.Two furnaces, two switch legs. I'll throw in a JB.
Actually, these upper crust clients like it when you give them the "industrial" look. I put a 200 amp fused disconnect in a basement once. The client is very proud of her "Frankenstein switch".
It's not like we're building a nuclear power plant here. I'm sure what works down there works up here in a residential utility roomThe plastic bushing can be used as long as the cable can be stapled within 12 inches from the entry point. I've been told by a very picky inspector that you have to refer to chapter 9 note (9) pertaining to multi conductor elliptical shaped cable for figuring NM in conduit. It then becomes a single conductor that is figured at 53% fill. Basically (1) 12-2 w/g had to be in a 3/4 pipe. Then I've had another inspector say maximum of (1) 12/2wg in a 1/2, and (2) in a 3/4....
Edit... My bad... You're in Canada...what a waste of typing for me...
You could maybe use a 1/2" EMT connector threaded into a rigid coupling on one end and an L16 on the other end.
single connector for armoured cable and 3/8 flex.pjholguin said:Please, define "L16"? Here we would get hit for a "put-together" not being listed.
