This is a story of my poor trouble shooting skill. I purposely left the s off of skills because that may indicate that maybe there was more than the half skill I have.
Well anyway, call from homeowner that microwave tripping the circuit breaker. Square D, QO 15amp breaker on 14awg wire, with general lighting & microwave loads. Circuit is over 20 years old and was running fine for that time until recently. First thing I checked for was overload on breaker. Turn on all lights and micro. Found 18.6amps on breaker. Breaker opened after a couple of minutes. Hmm, I didn't buy the overload. Something was telling me why was this circuit running so long like this. What changed. So, I installed a 20amp new breaker. Second test, same load of 18.6amps., breaker opened again but again after a couple of minutes. Feeling good now after discounting an overload. Third, was to check bus stab for heat buildup. Stab in pristine condition. At this time owners advise that the breaker only trips with micro running. Hmm, now looking for a shorted connection. Remove micro from this circuit and tested it on another circuit. Unit runs fine, no problems. OK, take the microwave receptacle out and replaced it with a new one. Reconnect micro and circuit holds good with no problems. I inspect and take apart the old recpt. because I couldn't believe that it cause the breaker to open. The old recpt. is also in pristine condition. Hmm, Now it was time to really scratch my ass. Here is what I missed. One, the couple of minutes it took to trip the breaker. Two, when I replaced the recpt. I notice that there was no outer covering on the NM wire in the NM Connector. Three, the box was steel and was grounded. Four, I pulled the wires apart in this box looking for compromised insulation. Seeing none I installed new recpt., keeping the wires apart as far a possible. Well I think you guys know what went wrong now......... The insulation on the NM wire in the NM connector got compromised over the years and after warning up for a couple of minutes with a load of 13amps, shorted together. Apparently after the wires cooled the micro would run again for another couple of minutes. I pulled in a couple of inches of wiring in the box, which was surface mounted, repaired compromised insulation and AMF. It appeared that the clamp on this connector crushed the insulation.
I learned much from this repair, and I hope this story helps another electrician. One day I hope to include the "s" in my trouble shooting skill!
