For a high end residential setting what looks better? 6x6 or 8x8 trough/wireway? Keep in mind this is only used for 12 and 14 branch ckts above panels to allow cleaner access back into panels through 2" x 6" gal nipples into top of panels so 20 percent fill or derating isn't an issue.
All panels are flipped with lugs and feeders coming into a wireway/trough running under all panels then into a mdp.
I think the 6x6 trough looks a little less industrial however less space to get your hands in.
8x8 def has a wow factor but a bit over kill. Of course sanded plywood painted dark gray first.
