1 - 20 of 31 Posts
I'm trying to install a Maestro dimmer but can't seem to figure out how to splice it properly since Maestros when used in a 3 way application require you to change the splice on one 3 way and change it to a single pole switch and put the dimmer on the end, which is no problem for me to figure out. But when a 4 way is thrown into the equation it makes it a lot more difficult. So here's my situation... On one 3 way it's fed, on the other side of the 3 way it is switched (this is the side the dimmer must be on) the neutral is sent straight through and what's left is a 4 way in the middle. It seems i've tried everything to make it work. Why are these dimmers so darn hard to install!? Thanks for the help in advance.
· Electrical Contractor
Yes standard 4 way swith, one 3 way switch and a dimmer. Fed at the 3 way, switched at the dimmer.
And yes I'm a 2nd year apprentice
Only Diva works with standard switches.
You have to use remotes when you use Maestro
1 - 20 of 31 Posts
