How do you guys test for a shorted turn in a motor,transformer or a coil ?. well i can't see how a megger can be used to do the test, i have only used a megger for P-P and P-G tests.
There are testers for this type of fault.
They send a series of pulses into the device,
If its good inductance wise, the pulses return ok.
If its not ok (shorted turns) then they wont all return,
So they count the number returning, the more the better,
Less indicates faults.
Such testers are used by electronics technicians to test
high voltage transformers in televisions.
But the concept is also used to test transformers or anything inductive.
