1 - 19 of 19 Posts
A job I'm working on I have a men's and women's bathroom next to each other. The lighting in them are both run off the same 120v circuit. Plans call for the roof top exhaust fan that exhausts both bathrooms to turn on when either one of the lights are turned on in either bathroom. The exhaust fan is also run off the same 120v circuit as the lights. What would be the best way to accomplish this? Can't think of any way to do this without back feeding one bathroom when the other is turned on. Unless there is such a thing as a contactor with two separate coils in it? Bathroom light switches are also fed from a line voltage occ sensor in the ceiling of each bathroom.
or you could use dpdt relays and occupancy sensors in each bathroom to make it automatic.
I've got the same situation going on as well, except my lights are A-B switching and on 3-ways. I'm gonna try using some if the power packs that came with the occupancy sensors. I'll take pictures.
All of our sites use the Occupancy sensor/ relay combo. It works pretty well as long as you use multiple sensors or keep them on for a long time. The Womens bathroom is always the first one to get a complaint about the lights are going out too soon. :laughing:
· Administrator
I don't agree. How would two SPST relays eliminate a parallel path to the fan? You would still have a parallel feed to the fan except it would be from the relay contacts instead of the double pole sws.:001_huh:
I didn't say relays (plural) I said relay- actually contactor. One contactor with 2 switches. The switches could be momentary contact switches. Where is the problem with that install. Either switch could kick in the contactor and only one switch leg to the fan. No parallel conductors.
· Tool Fetish
Thats complicated switching. Our local codes require the exhaust fans be turned on with the lights, not separate switches. The lights would be on contactors also? Is this so obvious that I just don't see it. :001_huh::001_huh:
I have just used the double pole sws in the past.:thumbsup:
· I like ceiling fans & EMT
We leave our rooftop exhaust fans on 24/7. The bathroom lights are on motion sensors. No way they would clear out enough air by the time the lights shut off.
1 - 19 of 19 Posts
