1 - 19 of 19 Posts
felonious smile.
I can't find anything not compliant with this plan, correct me if I'm wrong. New 320 meter at street, feed 200 amps to mb panel in main house, directly feed 100 amps to 3 bay garage/ pool house mb panel.
I've done it countless times. Nothing against code. However you must have disconnects at meter, and then each panel technically becomes a sub. 4 wires to each panel, neutral not bonded past main disconnect.
felonious smile.
Even with a remote meter at the roadside? That's a grounding pita.
General Superintendent
you only need a disco at the meter if the POCO requires it, you're not at a 'structure' that would require a means of disconnect
felonious smile.
That's where I was thinking.
Electricity is Amazing!
We do it quite often. The POCO will have their box with the disconnects in them. We do not have to have isolate our neutrals and grounds coming from them. Our local inspector said they consider them the POCOs service disconnect.
It must depend on the area. Here if you have this setup shockdoc speaks of, you must have a disconnect. No matter if the meter is remote or not. This meter/disconnect combo is handy for this situation.
Are you allowed to run this unfused cable directly into the home, or do you have to have a disconnect outside?
bml215 said:
Wouldn't the meter count?
Count as a disconnect? Never. A homeowner, building owner, tenant, homeless person, etc. can turn off a disconnect. None of them can legally pull a meter.
Armed and Unhinged
Ahh Ok. We run unfused lines into our homes over here then also.
Drop to meter then right into home to panel with main.
We do the same here. That's not what the OP was about.
Electrical Simpleton
The NEC doesn't care if there is a meter or not. The meter is a POCO requirement... not NEC.
Pete
Must be a POCO thing because you can have 2 services off one drop per the NEC. No disconnect needed at the meter. Each set of conductors coming off the meter are SE conductors and not feeders.
This is just for dwellings with a separate building or structure.
Do it all the time here. One 320A meter with dual lugs, go to house panel with one set of SE conductors and detached garage with the other set.
What if that meter was on the house? Do you still not have to have a fused disconnect for the conductors to the garage?
No because they are service conductors not feeders. Of course you have to have a panel in the garage close to where the conductors enter or you would have to have a disconnect w/OCPD on the outside.
Though it may be code, I personally would never do that. I know, I know, the underground coming to the house is done that way, but I didn't install that, the POCO did. Just my preference.
1 - 19 of 19 Posts
