1 - 12 of 12 Posts
Wondering what everyone's standard is on installation. Since pretty much every under cabinet style light fixture I've ever installed comes with a cord/plug setup, I've always cut the plug off and spliced my SL to the cord. I was never "taught" the "right" way to do them. I've never had any issue or call back for one. How does everyone else do them?
· Senior Member
I stuff romex out of the wall and then slam the UC light in there.
A weekend or two ago I wired for UC lights in my kitchen. I had a couple scraps of 120V rope light that I threw in there; they were supposed to be plugin but I cut the ends off and spliced them in a shallow Wiremold box on the underside of the cabinet.
They were decidedly underwhelming :laughing: I'm gonna replace them with some sort of LED strips at some point. The hard part is done, though (wiring).
· Banned
I use 18/2 for LV under cabinets, cut the tails of whatever the light is, and crimp using butt splice connectors. Hide the wiring in a channel cut into the false bottom in the cabinet.
If it's a reeeeally long run, I'll bump up to 14/2.
· Premium Member
· Jesus Scott
How would you ever think that's the right way to do it regardless of what you were taught?
Buy a fixture that you can wire and not a portable fixture.
· Retired Account
Usually because UG, OC, or InC luminaires are subject to the cabinetry , which most times isn't chosen @ rough 99
My personal pet peeves include exposed nm, lack of cabinetry light bar , and a general lack of plan by designers , archy's , cabinet suppliers who all insist on our installs being after the facts
· Moderator
Estwing magic
This, this and this:
· Moderator
Estwing magic
The only time I splice is when the factory jumpers aren't long enough or if I'm running 18/2 during rough-in. You hardwire these things, you don't cut off cord ends. You really have to quit buying UC lighting at Walmart :( .
1 - 12 of 12 Posts
