Status
Not open for further replies.
1 - 8 of 8 Posts
Hello friends,
I was upgrading an old 2 prong in a house I recently began renting when I ran into a snag. I'm an amateur, but am very handy (famous last words) and I was checking another 3 prong outlet in my home for an example of how I should wire up the 2 prongs I plan to upgrade. I shut the breaker off, so the pics will be dark below, but basically whoever fitting the 3 prong on the socket prior to myself living there did not ground the socket. Meanwhile I've been using it to plug my surge protector onto with a couple grand in equipment assuming it was correctly grounded. Never fear, this is now a another project to check grounds on the current 3 prongs.
My issue is, am I missing something? What the hell is that green wire tapped into the ground tab for? I have the black and white, but there is a green coming from the back side of the metal box too, and wrapped around one of the grounding screws which you'll see clearly in the pics. Is this confirmed that my box is grounded? Should I use the same tab the ground is on to ground the socket, or use the bottom one? I assume they would both work fine, but I don't want to mess up the old ground length on that top tab.
Any advice on to to proceed would be excellent. Thanks!
Is this forum for like elitist types only or something? I didn't see any disclaimer stating an amateur could ask a question... has this been covered before? Could you perhaps point me in the right direction to where it has if that's the case?
Thanks for posting on ElectricianTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
I know the pic is small, but is CLEARLY stated in the sign-up page:
Reactions: ampman
1 - 8 of 8 Posts
Status
