1 - 20 of 115 Posts
I don't have good success using a holesaw for making KO's in steel.
I have been using a hydraulic KO punch set, but even making the first hole, our Unibit was too dull.
Tried using a brand new Milwaukee holesaw for a 2 1/2" in Nema 3R box, and killed it fast.
Any Tips ?
Coffee drinking member
Use a plywood jig to keep your oil in place.
Discussion Starter · #11 ·
Those uni-bits are garbage for drilling holes in steal.. IMO....
They dull easily and are way over priced..
I start out with a 1/4" bit.. then 3/8 and use the punch with slim post and 1/2" KO....
Wut !!!! Worth every cent
Scotchkote Installer
he still uses a pager
don't listen to him
Oh you mean the paging devise that has NEVER missed a call and even worked 100% during superstorm Sandy...
Even works is the basement of a commercial building..
Make all the jokes you want.. works 100% of the time when customers need to reach me NOW.. :thumbsup:
Discussion Starter · #16 ·
I have (7) of them and they all suck when drilling holes in a panel..
WOW.. just WOW.. :rolleyes::rolleyes:
Sorry, disagree
I once had my helper ruin a $56. dollar 1" Unibit, drilling Stainless Steel. Probably could have pulled it off by drilling slow rpms using cutting oil.
Questioner of Authority
Do those cut clean round holes, or start oversizing like the regular holesaws do ?
They cut good. The arbor is the same arbor from the hole saw kits. The 1/2 and 3/4 arbor is effective, but it jams up. I use mine any time I can. I even use it to blast a hole for the ko set if I need a bigger hole. I use a little cutting oil usually, but it does fine without.
sometimes I laugh at you
sometimes I feel sorry for you
with that remark Im not sure which way I should go
I always preach the carbide cutters. Unibits are nice and they have their place but I don't believe they're the best option for new holes. My method is center punch, 5/32 pilot hole, 1/2 or 3/4 carbide, KO punch. I've been doing it this way for a while and make a ton of holes every day. Jobber bits are super cheap (or free depending where you work), and you can easily get a couple years out of a carbide bit if you take care of it
1 - 20 of 115 Posts
