1 - 17 of 17 Posts
I was wondering what would happen to some HO T12 Flo lamps if they were installed in a fixture that had a VHO ballast?
I know I read somewhere that if you re-lamp a HO ballasted fixture with VHO lamps then you would only get the amount of light that an HO lamp can produce from the VHO.
Both lamps are F96 T12's High Output vs Very High Output. Ballast is for 2 VHO's, 1500 ma.
Well, we put a couple of HO's in a VHO fixture and it worked but the question is for how long? Thoughts? I want to think that the lamps will burn out prematurely.
RIP 1959-2015
They will burn out faster and burn much brighter remember you are running 1500ma through 800ma lamps.
It will be fun watching them flip-out when they start burning out..:laughing::thumbup::laughing:
Modérateur
Yeah that and also they are a power hog as well.
And the VHO bulbs are not cheap as well
Do you guys remember the old Power Groove bulbs ??
I know they are about history now.
Merci,
Marc
People buy HOs all of the time and put them in VHO or SHO fixtures and then can't figure out why the lamps keep burning out. I can usually spot the VHO fixtures because the sockets are normally a bit taller possibly to accommodate the PG17 powergroove lamps Marc posted a picture of.
That's what I was thinking. I ordered the VHO's so I can get it done right the first time.
RIP 1959-2015
They used to have those up here man i miss those.:(
The four HO's we put into VHO fixtures, yesterday, two already burned out. That was fast. We bought 4 cases of F96 T12 VHO's. Man, they were expensive.
Modérateur
Outdoorguy.,
If you don't mind if you tell us the ballpark the price you get the staight T12 VHO bulbs the last time I have to buy in France was 44 Euros a pop.
For the Power Groves we call them PG17'ers due the bulbs size is larger { pretty rare I get a PG12's }
BTW the PG17'ers are at 215 watts same as staight T12 VHO unless you got reduced wattage verison which they run about 180 watts or so
Merci.
Marc
Discussion Starter · #12 ·
Outdoorguy.,
Merci.
Marc
For the 4 cases of VHO's (15 lamps per case) and we also purchased (6) 2 lamp VHO ballasts for said lamps, our cost after tax was $861 USD.
Discussion Starter · #13 ·
Merci,
Marc
What is the point of the grooves in these lamps? I have never seen such a thing.
Modérateur
Ok I will fill you in a bit with this one the reason why they put the grooves in there so they can force the arc to travel longer distance instead straight shot.
Like example I will use the 8 footer lamp which you are famuair with it and with the grooves it will extend the arc longer to like 9 or 10 footer so the manufacter claim it will generated more light per foot.
And there is a nice bonus .,, they make the tube more stiffer so they can not shatter easy as straight tube verison is also pretty much elemated the swriling action when they are on.
IIRC they did came in 4 footer verison that even more rare than 8 footer is.
Merci,
Marc
Electric Al
It give the lamp more surface area.
Those groove lamps were very popular over gas pumps, in the sixties!
I had a bunch in stock for many years, couldn't give them away.
I did not know the reason for the grooves.
Thanks for the info, now that I know, it makes me a more well rounded or groovy individual!!!
:laughing::laughing::laughing:
Try to sell a retrofit with t8's. The kits go in lickety split & the energy savings (not to mention maintenance costs) will pay for the work in a few years. Up here the POCO (PP&L) will even chip in a percentage of the cost, though the paperwork is excruciating.
1 - 17 of 17 Posts
