Do I need a switch for an electric water heater (residential) where the panel and breaker for it is 8' away in the same room?
Had an inspector try to get me to put in a disco or lockout. He said" someone could build a wall between the panel and the water heater". I didn't comply.Xknob&Tube said:Do I need a switch for an electric water heater (residential) where the panel and breaker for it is 8' away in the same room?
Sounds like a dumb inspector. State inspector a city inspector?Had an inspector try to get me to put in a disco or lockout. He said" someone could build a wall between the panel and the water heater". I didn't comply.
State. It was a open basement, maybe 24x24.Chris1971 said:Sounds like a dumb inspector. State inspector a city inspector?
But the NEC requires it so you are in violation every time you wire one without a disconnect.We are not required to provide disconnects for residential water heaters, only commercial
I'd just like to know how many horsepower "1⁄8" is.But the NEC requires it so you are in violation every time you wire one without a disconnect.
Or, does Arizona exempt residential water heaters?But the NEC requires it so you are in violation every time you wire one without a disconnect.
If it has a written amendment you are correct but my bet is that they don't. This area also has a lot of things they allowed but the NEC does not.Or, does Arizona exempt residential water heaters?
Sorry I'm missing that one, it says or "300 VA"wildleg said:I'd just like to know how many horsepower "1⁄8" is. I'm thinking of adopting that into my job lingo. "Hey, bring me over a one and frazzle 8, and be quick about it !"
Did you mean to text your apprentice or the entire ET community?
Metallic Clips ?When roughing in houses we put metallic clips on breakers that feed hard wired equipment such as dishwasher and hot water tanks. This provided the lock out means and eliminated disconnect means. They were quick and afforable. This would even apply for HVAC units. I feel commercial equipment is another story.
