I have a customer who has a water heater with 2 elements. The one at the top and bottom are both rated at 4500 watts, but the water heater itself is rated at 4500 watts maximum.
Is each element rated at 120v and 4500 watts?
My guy who is there says that when doing a load test, the water heater is showing 37 amps and tripping the 30 amp breaker. If they are only rated @ 4500 watts, 240 volts, then how can this be? Are they designed where only 1 element can come on at a time?
