We have a customer that has a new large home we did the electrical for last year. It has a 400A service and a 50kw automatic standby generator. They should have closer to 100kw but 50kw was all our suppliers had access to last fall. There are quite a few heating loads on the on the service so i imagine the 50 is working plenty hard but is keeping up during the recent outages they had.
During todays severe cold outage, the water pump didn’t run but after the power came back on so did the water. The transfer switch feeds a 400A distribution panel then branches off to 3 200A panels in the property. They have a constant pressure pump controller, we’re going to simulate an outage next week and see what’s up. My guess is during very cold weather during an outage it may not be getting sufficient propane flow and the load would be increased. That would cause frequency fluctuations and possibly the pump controller may be rejecting the source. If that is the case should we add a UPS to feed the controller and if so how big? Maybe I’m way off here just drawing straws at the moment.
