Shoe Goo works wonders from what I have seen.I'm running 2- 21/2 conduits under slab from meter into basement and need to make sure the sleeves are water tight after I run my conduit through. Anyone have a good recommendation for a sealant? Epoxy?
I agree, this is what we use when we can't take a chance it'll leak.
In all seriousness how do you have time to do that? I got to get my arse to the next job most of the time so Ill spray foam cavitys and seal with caulk.I have always used spray foam and after it dries give it (3) coats of automotive undercoating...
I never had a failure yet.. :thumbup::thumbup:
I make the time to do the job right and plan on at least half a day...In all seriousness how do you have time to do that? I got to get my arse to the next job most of the time so Ill spray foam cavitys and seal with caulk.
Awesome way to seal esp in manholes... But u need exact measurements... Hole diam and pipe diamKiknads said:
Wonderful stuff also... Dont get it on ya, its as ba as exp foamRandyM said:Geocel sealant. Put some duct tape around the lower 3/4 of the joint until it sets up.
