1 - 20 of 50 Posts
Intro:
The new proprieta of my favorite watering hole has, with much elation to myself and fellow patrons, showed interest in reviving the currently immobile ceiling fans above the bar.
Problem:
As it has recently come to my attention, the multiple pendant lights over the bar are currently on the same dimmer as the two fans. Obviously there is integral problems.
Theoretical solution:
Find the ratio of the amperage normally applied to the pendants while dimmed to the pendants amperage at line voltage. Then change the wattage of the bulbs in the pendants so that, at line voltage, the same wattage is achieved.
That's a bit of a mouthful but we all know that watts = volts x amps.
Does it translate in a practical sense?
Summation:
Can I achieve a resemblance to current ambience by altering wattage at 120 volts as the dimmer alters voltage to a higher wattage bulb?
If someone always used a dimmer at 50% on a 100 watt bulb, would replacing the dimmer with a single pole switch and replacing the 100 watt bulb with a 50 watt bulb produce identical lighting?
Data Tech/Apprentice.
Intro:
Problem:
Summation:
You could have had romex across that ceiling in the time you typed this out.
Why dont you just experiment with bulb sizes until you find one that produces enough light at the normal speed setting for the fans !
Make sure that the speed control can handle the extra load of course !
Intro:
Problem:
Summation:
Dear sir, if you are going to compose these type of posts could you please not do so on Friday nights since this type of stuff gets really difficult for my mushroom high at peak time mind to gather together and decipher.......
Reactions: sparky970
Now, wasn't that easier!
Dimmers do not change the voltage any more, it changes the current.
I own stock in FotoMat!
Remove dimmer.
Install SP switch.
Remove canopies on fans and install remote controls.
Bam! Problem solved.
1 - 20 of 50 Posts
