What is that for? Other thank complex switching. 240v 4 way?Celtic said:Something like this?
I have no idea :laughing:What is that for? Other thank complex switching. 240v 4 way?
Try and keep up...that was said 4 hours ago :laughing:Lots of uses. Start with "switching".
I once installed a switch as you describe to separate the heating from the cooling with a "center" off position. Is this what you are taking about?I am having trouble finding a diagram.
Used one for the same type project, winch on the back of a snowmobile.I thought a saw a goofy one like that for an electric overhead door to handle the motor reversing? I had no diagram but built one.. It was designed so that 5&8 were reversed in each way, and all isolated in the center.. Good thing I had a meter and a scrap piece of paper...
If you can sketch how your switch terminals meter in all 3 positions that would be handy.. If it has only 2 sets that seem to cross, and one set that stays the same that would be a reversing switch...Looking at the diagrams I think they are reversing switches.
