921 - 940 of 1020 Posts
I work for a service shop. No complaints, love what I do.
@Kevin
Is it cheaper to rent/buy a bender vs just buying the fittings? My company always buys the fittings, seems like a faster way of running pipe. Are fittings THAT expensive to where it's cheaper to rent a machine and spend the extra time bending?
Where do you buy a 2" stick of rigid with a 1-3/16" offset on one end and a 3-1/4" offset on the other end facing a 90* quadrant the other way?
You must have better wholesalers, or just do work in wide open spaces.
Bilge Rat
motors and controls.........
Yesterday, I replaced the kitchen sink at my daughters house. It was a cast iron model that had seen better days........and the new one is a stainless type.
Both were standard 22 X 33. Removing the old one was not too bad.
Usually, with this size of sink, the lower cabinets are 36" apart however, the idjit that did the cabinets had only 31 1/2" between them. I had to cut the countertop (formica) a bit larger in both directions and modify the side of one of the cabinets.
About an hour later, the new sink fit.
Ever notice how nothing ever goes as planned...........lol.
Idk I've been using fittings for years and have never ran into an issue or a scenario I can't figure out. If I need a 1-3/16" offset, I use a 15 degree and cut some of the straight piece off the end of the 15 and/or 90 to achieve the desired length for the exact offset measurement I need. Same with the 3-1/4", maybe for that I use a 30 degree and apply the same method. There's no offset I can't achieve with fittings. I usually plan way ahead and pick routes that work for what I have to work with. Idk hard to comment b/c I haven't ever run into a problem yet. I assume using a bender does cut cost though. Hell I've never used one so maybe it's easier and faster as well. Probably not for everything but if you're working with 2" rigid and have to thread everything together, then yeah I'm all for that bender for saving time and $.
The years spent working in your daddy’s cabinet shop payed off on this job.
My papaw always said the main difference between an amateur and a professional is a amateur will work themselves into a corner, but a professional knows how to fix the mistakes and cover them over.
Just trying to get home
Site Engineer
Me too then remembered, im jewish
That doesn’t seem to matter one way or t’other these days. I have a few Jewish friends that have ”celebrated” Christmas for decades.
Site Engineer
Reactions: Majewski
Bilge Rat
Lol....exactly right, on both counts!
@Kevin
The pipe that we needed to bend was to mount a camera, hanging over the side of a building. We thought about making something out of ready-made fittings, but didn't want to chance it. Last thing we need is a coupling failing and sending an object falling 80' to the ground.
Also, they had issues with the camera wobbling with the wind using a pole made out of one piece bent to the shape they need, I could hardly imaging how much extra movement there could be from unnecessary couplings.
Tonight I’m working on a Steffes forced air storage heater. The PoCo quit selling and serving them so we had to. Then we weren’t selling enough of them so they took them back over. But it New Years Day and they don’t want to come out. I have no parts, I can only troubleshoot and it’s going to be -40 tonight. Oh, and the owner lives 250 miles away. But I got it to start heating and the stored heat level is up to 25%. Hope it holds on and keeps running.
Rectangle Material property Wood Gas Composite material
