1461 - 1480 of 1517 Posts
Is that poured right up against the building siding or is there foam or some kind of expansion material between the building siding and concrete? Just curious.
It’s the remnants of an old wall of a building that is now inside a larger building. I just put the concrete up against the steel of the old wall, no expansion foam. It was a quick and dirty job that I formed and placed in the span of an hour, the driver was heading back with a yard or so from the job he was as at, and it was pure get er done.
electrical contractor
Changing out a bedroom window from a 4'x2' to a 6'x5'.
That sounds like a lot more work than I would want to do.
Dealing with whatever siding is on the outside, sheetrock inside. Install a new header. Nah. :)
Reactions: Almost Retired
I'm doing generous-sized window trim, so the outside part is relatively easy. The existing header was wide enough, so i recycled it.
Can't afford to hire people for this stuff so this week i'm a hacky carpenter. :p
Comfort Wood Bed frame Floor Flooring
changing my window unit from worn out on board digital controls
to a central air thermostat with a txr and two contactors
first pic, controls mounted and wired
next step is to tie into the unit power, then comprsr and fan directly
(before i do that, i am using it to cool the room lol)
and yes i am going to leave it all just like that surface mounted and exposed
i live alone, no one here to get hurt
Electrical wiring Gas Electricity Technology Electrical supply
Uh oh, there’s no wire numbers or a ladder drawing.
The usual suspects will be along to scold you directly.:whistle:
stage 2
hooked up and running
but not finished yet
gotta cool the room again lol
next i will put it back together run the wire thru the lower right of the control panel
Gas Fixture Electricity Electrical wiring Art
