Hello All. I have a question about where to find something in the Code. For a Service to a Home, Homeowner owned pole with SEU Cable down to Meter/Disconnect, 2 ground rods with EGC from Meter Socket, then underground with Rigid PVC Conduit to and thru Building Foundation and into Breaker Panel. Run in Conduit is 2 Ungrounded Conductors plus 1 Gounded Conductor. At Panel another EGC run out thru Foundation to 2 additional ground rods. NO Grounding Electrode Conductor in Conduit Run.
What article and section in the NEC lists this Installation please?
I cannot seem to find it either in 230 Services nor in 250 Grounding.
