1 - 20 of 32 Posts
Hello.
Some time ago I peeked through an open manhole in my city. It had some red thick cables. They came from buried conduits and ended in an object I will attempt to describe: It was a black piece of plastic whose body was cylinder-shaped, around twice as thick as the cables. From a side of this cylinder 4 other slightly smaller cylinders protruded. These lateral cylinders ended in the cable itself. I didn't took a photo of it, but I was able to find this image, which depicts something similar:
However, the body of the object I'm trying to describe was somewhat sorter. How is this called and what it does?.
I have read about electrical distribution systems but there was no mention of this object.
Thanks in advance.
· Salty Member
Hello.
Thanks in advance.
Pretty sure It's just a type of splice, kind of like the plugs on Christmas tree lights, you can stack some together.
Thanks you very much guys.
So, if I understand correctly what I called a single object in the picture is actually 5 separate pieces joined together. That makes sense; but I think the one I saw personally looked like a single piece, is that possible?. Are these used for medium voltage only?. Are the elbows at the end the same thing as the elbows used to feed transformers?.
· Salty Member
I think at least 5.
Big John will have to pick up here, I do not know.
Sorry if MTW and I derailed things.
· Electrical Contractor
Why are you so interested in this? Are you looking to salvage???:laughing::laughing:
· Coffee drinking member
Maybe he should just cut it out.. Its kinda useless anyway,, right?
I've seen them in manholes. Basically like bbq said plug n play. The last time I came across that was Y2k and we were disconnecting a switch gear feed that came out of a sub station into a manhole and had that contraption. They didn't want to fool with that mess and tried the old safe it off in a mason jar ( I know old school). It didn't work and when they energized that mother it blew a hole the size of a fist out of the J box.
1 - 20 of 32 Posts
