1 - 4 of 4 Posts
what are the best kinds of electrical connectors that isn't too expensive?
I need to stock some generic electrical connectors (probably a few hundred for the next 6 months for our factory). I don;t know what the specific purpose is yet but probably a lot of lighting, pumps, panel boxes, motors and other machinery?
I would need plastic connectors but I think I prefer to have them easily to connect/disconnect.......
Any recommendations? I found a few but havent used them before,....
Push-pull connectors
http://www.keywolf.com/plastic_male_solder_plug.php
http://www.fischerconnectors.com/
DGFVT
Does this have anything to do with "lean" manufacturing? If it does you gotta lot of preplanning to do. I have one customer that does this and there is a big price tag on being able to move machines and equipment around "as needed".
Standardization is mandatory.:thumbsup:
animal lover /rat bastard
you need to do a careful and thoughful analysis of exactly what you need to standardize the environment (as others indicated). volts/amps/wiresizes along with an inventory that is specifically tailored to the predicted failure rates or refitting rates that apply to your specific installation. This will involve a careful and thorough analysis of all the systems and equipment involved. No simple answer here; just a time consuming list you need to create.
1 - 4 of 4 Posts
