I was once told that the ground screw is what is really supposed to hold the wire in a box while the clamp which should not be overly tight is not sufficient on its own because it should be left loose enough to wiggle the wire a bit and if someone were to pull hard enough it would come out at that tightness.. hence the ground being tied into the ground screw is what is really holding it securely in the box. What do you guys think?
I belive he worded it like this " the clamp holds the wire while you secure it onto the ground terminal"
Ps. Hi everyone. My first post but I have read lots if threads over the years.
