Ok, so i got to a service call. House has been rewired, new panels and the like. Looks like the guy did a decent job. problem is= Arc fault trips. heres' what i did. Take down the offending light fixture and take off the hot wire. flip the switch and breaker stays on. take the lamps out and hook the black back to the fixture and it stays on, then i screw in the bulb and pop. So i switch the polarity on the fixture figuring sometimes they are wired wrong from the factory. Nope still trips. Hang a brand new outta the box fixture....same deal. i figured next its the breaker so i pop in a new breaker and same gig. then i check the switch for another wire in the circuit but figure not gonna be it because its stays on till i flip the switch with bulbs in. isolate the feed in and switch leg. still trips. so short of taking a piece of romex and lay it on the ground wired to the switch and fixture (which i didnt do) i know its gotta be the nuetral on the switch leg wire. we all know the bulb completes the path back on the nuetral and thats what the arc faults sense. so log story short i wasnt gonna fish a new wire notch the ceiling and all that because the propery owner wasnt having it and just wanted it safe. so i put it under a regular breaker and all is on. I figured the clamp pinched or a staple made the nuetral come in contact with the ground. what would you guys have done?
