1 - 8 of 8 Posts
What's the best toner on the market?
I'm going to have to buy one because of some mid marked wiring. I was going to just grab witch ever one they had at Home Depot but figured if I'm gonna get one y not spring for the best available
The Pro3000 is analog only. I think the digital model (I forget the model number) will also do analog. In digital mode it has a very limited range (~300 meters). I have both, and typically use the digital one for identifying Network cables connected to live equipment. For telco tracing or cables that aren't connected to anything on the other end, I will use the analog one.
I don't know of either could be safely used on energized lines.
Sent from my Moto X using TapaTalk
1 - 8 of 8 Posts
