1 - 20 of 41 Posts
Wires aren't spliced..
No wire labels...
No marrette on ground..
No cover on box..
Couldn't tell, but is there a tail for the grounds to the box?
Someone lost the 8/32 screws for the cover?
I didn't finish making up the box, the thread was more of a rant on the layout that led to 7 entries into the box.
We don't have to pigtail the box since the run is all emt, and the screws are missing because they come with the plenum cover.
Discussion Starter · #18 ·
Better read 250.148(C).
The way it was explained to me is, the equipment grounding conductors are connected to the metal boxes at the fixtures.
The grounds installed in the FMT and EMT are not required by Chicago code and are just a job spec. Therefore the ground wires in that pic are not equipment grounds.
I am by no means a code guru and this explanation was sufficient for me.
· Electrical Simpleton
What do the spec's call that green wire? I would call it an EGC and treat is as such... needed or not.
Pete
1 - 20 of 41 Posts
