Good question, I will be looking forward to the awnsers to that one.
517.18(B) (See also (C) )I am currently working on a project that is a medical office building. I need to know exactly where i would need to use Hospital grade recepts? There are exam rooms, x-rays, procedure rooms, dialysis area. Once again this is a medical office building. I was reading through the spec book, but nowhere does it spec out for any hospital grade devices.
Please advice
Thanks.
We did a dentist's office, and no hospital grade receps were required, but the 10 treatment/examining rooms needed the redundant grounding (HG-MC)I have always seem them required by specs in patient treatment areas (therapy machines/etc) or areas where medical gases are available for use.
I am not sure what the actual criteria is that the engineers go by but that is the way I always see it, rooms were patients are seen/treated always have them required. The last time I was involved in doing a surgery center I had photo copies out of the code book they usedWe did a dentist's office, and no hospital grade receps were required, but the 10 treatment/examining rooms needed the redundant grounding (HG-MC)
A rehortical question here: what did your estimator/project manager put in his/her bid take off for those receptacles ? Ask him/her for the bid basis. YOU are the one who will catch heck if you go over budget. Doesn't seem as this is your call. YOU will be the victim in this scenario.I am currently working on a project that is a medical office building. I need to know exactly where i would need to use Hospital grade recepts? There are exam rooms, x-rays, procedure rooms, dialysis area. Once again this is a medical office building. I was reading through the spec book, but nowhere does it spec out for any hospital grade devices. Please advice Thanks.
Is this a policy of the hospital, a locally enforced rule', or is it something the maintenance dept started doing on their own?HG receptacles are to be installed in all patient exam and treatment areas of the hospital regardless of use.
