1 - 20 of 42 Posts
Always learning
We are modifying an existing panel and the specs say to use "thermal type vinyl self laminating wire markers." What's label maker would you recommend to do this?
used a brady bmp21 on a roller coaster i did all the control wiring on, easily a thousand labels and no worries. it performed great and is still going strong.
good luck:thumbsup:
chris
You can check out the Rhino Industrial Label Makers. They do offer the possibility to use self laminated tape among other types of industrial tapes. You can always take a look at our webpage to check the available tapes and functionality of the devices.
The Rhino 6000 is PC connectable and offers a width of tapes up to 24 mm.
http://tinyurl.com/onkvkyd
In this link you can also check out the Rhino 5200
http://tinyurl.com/l98prdt
If you have any questions about the devices, don' t hesitate to ask.
^CP
I have a 3M PL200....I had a PL300 (Cadillac version) until some ass stole it. They are good labelers. When I bought my PL300, there was a deal with City Electric Supply if you bought so many labels, the labeler was free. That deal wasn't going on when I replaced it, so I just bought the 200. It was $209. The 300 is $409. the 300 can be connected to a computer, and will do self laminating labels. They are heat transfer labelers.
I will be getting another 300 some day, I figured the 200 would be good to have on my job truck for day to day stuff....and then I will put a new 300 in MY service truck sometime.:laughing:
Mostly Harmless
I have a Brady, don't know model. I hate the goofy looking "9" it prints and always use a capital "O" instead of a zero because the zero has a line through it. I do use the slash/zero as a "phase" symbol though!
Just my $.02
Funny that the "9" is goofy yet the "6" is normal!?
Discussion Starter · #12 ·
^CP
So which tape works well for labeling wires in a control cabinet? Then which tape is the largest most durable for panel names etc.
i liked the id expert up until it wasnt strong enough to spit out the label itself. have to kind of help it along. but its easy and you dont have to change it for different types of labels. every different label has a chip whether doing noodles, wrap arounds, or continuous like you were talking about. this labeler was a huge contractors so it had a pile of miles on it.
Rhino Labels
The Flexible Nylon tape works well for labeling wires, cables and curved surfaces in general. The adhesive resists moisture, extreme temperatures and UV light so labels won't curl or fall off even exposed to such conditions. The self laminating labels offer and extra protection for labeling wires since they are also resistant to oil, solvents, water and abrasion.
About the panel names, the vinyl tape is perfect since it combines a strong adhesive resistant to moisture, extreme temperatures and UV light. They are available in different colors that adhere to OSHA, ANSI and ISO color standards.You can take a look at all the labels in the following link. ^CP
http://tinyurl.com/o9b6xtl
Tool Fetish
We have 7 or 8 K-Sun units. :thumbsup: Still have 3 of the big old Brady top of the line (BMXC)?? printers that sit in the office. Once you use the K-Sun heat shrink labels you won't go back to the Brady shrinks; the K-Sun shrink labels shrink in about 1/4 of the time and look 100x better. Nothing beats the Brady for saving and reprinting lists of labels though. If we have thousands of labels for a job, we will print the masters in the office and use the K-Sun to make corrections in the field. Also have a K-Sun printer that runs from a PC but haven't tried it yet;
waiting to run out of the Brady labels since the old BMXC printers are not supported any more.
"pause to cut Btw label" not shutting off
I have a brother p-touch now but I am buying a dymo rhino 5200. It seems to do everything you could possibly need.
Don't buy any dymo, I bought dymo 6000 / pl300 over few years ago and now it is cutting every time I print.
Tried: resetting pulling batteries hitting on/off 15 or 20 per support group default it. then try shutting off "pause to cut Btw label" now i need to send in for repair $120.
I paid over $450 onsite at a job worked fine there and now not working.
i think it is firmware / software is bad. they said they can't send out firmware / software fix to me.
We are sorry for the inconvenience but not every device includes the auto cut function. Label Writer 450 Duo , the Label Manager Wireless PnP and the Label Manager 450 are all devices who include this feature.
On the other hand, Rhino devices do not include the auto cut function so you have to manually cut the tape by pressing the cut key. Please, if you do have any questions on the functionalities of our devices, do not hesitate to contact us.
^CP
1 - 20 of 42 Posts
