This is pretty much it:
Set Includes: Slotted 3mm (1/8"), 4mm (5/32"), 5.5mm (7/32") , 6.5mm (1/4") * Phillips #1, #2 SlimLine Blades
www.wihatools.com
I’ve also considered getting an insulated ratchet/sockets for doing the utility connections after a service upgrade, but think a pair of hot gloves would be much cheaper and could probably suffice.
the biggest problem i see with voltage insulated tools is the first time they get a nick in the insulation, they are technically not voltage insulated anymore
for 120/240V i keep a pair of plain all leather work gloves
they fit very well and dont decrease my dexterity very much
i dont use them for anything else, so they stay clean and dry
clean and dry leather is sufficient in my experience
working inside a meter base with a wrench concerns me more than anything else
that wrench will invariably touch the case if i dont take my time and watch it carefully
since i am wearing all leather gloves i put my hand on the tool so that is is insulated where it is most likely to touch (end of the handle for instance)
i have taped the shaft of my very small tip terminal block screwdriver for the same reasons that paul mentioned
but that is the only tool i have taped,
and i dont own any factory voltage insulated tools
my ideal strippers have a plastic cushion grip and i use them as needle nose pliers quite often
i worked in industry for 12 years, including offshore (think explosion proof everything and corrosion resistant outdoors)
initially i was allowed to work 480 hot, but soon found that if it needed repair, it wasnt being used, so why not turn it off and avoid shorts
a few years later, 480 hot work was outlawed almost every where
since then 120 or less industrial controls are the only thing i work hot for the same reasons that paul mentioned
sometimes i wear my leather gloves for 120, but not below
i dont even do resi hot, i have a breaker finder and just turn it off
it isnt worth the risk/cost of damaging what im working on
not to mention the customer's opinion of you causing explosions in their house lol
