1 - 20 of 26 Posts
OK so I knew that would get some attention. :eek:
I got these pics from a home inspection, I have to go look at it and give an opinion. It's an outdoor all in one (very common here). Besides the white powder there is signs of heat on the bus. I see rust coloration between some of the breakers in one of the pics also. My guess is water intrusion. I have seen slight deposits of the powder before in outdoor panels, always right there at the terminal screw, but never this much. Anyone familiar with it?
Some type of salt? What are the environmental conditions like? Is there any powder in the bottom of the can, or just on the breakers?
Dry desert. Don't know if it's in the bottom of the can till I go out there. I think if there was any in the bottom of the can the HI would have mentioned it.
Like I said I've seen small bits of it before right at the breaker screws, but never this much. Seems like it's always ITE/Siemans/Murray type breakers too. I will probably tell them water intrusion, and that I cannot guarantee anything short of a panel replacement.
· Bilge Rat
motors and controls.........
I'm going to guess that this isn't heat, but rather some sort of chemical vapor.
If the bus got hot enough to become discolored, it would have melted the plastic behind it.
Odd as this may sound, was the garbage can below the panel?
The discoloration of the bus looks sort of like a weak attack by hydrogen sulfide gas.
This is not the absolute truth of course, it's just one possibility.
Arsholeprentice
I see the same thing on those breakers here too. If you get a new one, the white powder is solidified right where it is coming from. I'm not sure why it does that, maybe a good question to pose to Siemens/Murray?
I agree with Switched. I would get the local Siemens rep's email address and send those pictures to him with WTF?
1 - 20 of 26 Posts
