1 - 17 of 17 Posts
And what is the likelihood of this one accepting twins?
Realtor sent me the pic, I can't get out there for a couple days.
Call the realtor and ask them for a better picture that has the label clearly shown. It should have a list of all the breakers the panel is approved for. Which is not to say others may not physically fit, but they aren't listed/approved.
It looks pretty old. Most of the older panels are listed for tandem breakers. It's the newer ones that are CTL (circuit total limitation). I believe prior to 1965 all panel could have tandem breakers. How old is the building? Is the sub-panel original? Hope this info makes sense and is helpful.
NJ-IEC
It's a CHCH panel and those are the only breakers you'll be fitting in that panel. IMO that's the benefit of a CH or QO.
Can't Remember
Looks like a couple of empty spaces. Unless you are planning on adding some, you are all set even if not listed for twins. Go forth, make money.
Discussion Starter · #12 ·
Home inspector said no more room so I have to assume there are no bus stabs behind those two KOs
Discussion Starter · #13 ·
Thanks, the building is 1960
1 - 17 of 17 Posts
