I have read it goes back a very long time, back before household electric washing machines and dryers where so common. It was for electric irons, steamers and such.Is there a good reason behind this code?
Unicorns and rainbows and glitter.All outlets should be on
20 amp circuits.
20 amp circuits.
:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:That would be good for the appliances I own that have a 20A plug on them, oh wait that number is zero. I will stay with 15A circuits.
Definitely is an American way of thinking. I did 3 american stores over the last year and they all had 20A receptacles in them. Us Canadians would slap in 15A receptacles and still be good.:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
No, you can plug in the washer there too.pete87 said:I thought the 20A Laundry Circuit was for the Laundry appliances . Iron and so forth . The washer can be on a 15A circuit in the same area .
I have installed 2 circuits in High End Ressi quite a bit , but i run both 20A anyway .
Pete
Yea i know . But the code requires a 20A laundry circuit be installed in the laundry area but as far as i know , there can be a 15A circuit there also andNo, you can plug in the washer there too.
Not sure what what you getting at, our 20amp plugs in Canada will allow 15 or 20 amp appliances to be plugged in. And yes we can get just a t-slot 20amp. But that wouldn't work out so good on a kitchen counter. Or laundry room.darren79 said:That would be good for the appliances I own that have a 20A plug on them, oh wait that number is zero. I will stay with 15A circuits.
Crazy. :jester:Always see a split circuit 12-3 wire even in older houses, with a dedicated to the washer and dryer 120V. This is besides the 20A to the laundry room.
Could have been your old jobs I was seeing ! I'm also doing the Shockdoc method.used to always run a dedicated 20 amp circuit for the washer
and if they had a gas dryer I would run a 20 amp circuit for it too
and if they had any other receptacles in there I would run another circuit for them
now......theyre all on the same circuit
Shockdoc would be proud
