1 - 19 of 19 Posts
felonious smile.
Not a bad way to strip conductor insulation ..... i should concoct that, the smoke is legal since there is no fire.
I own stock in FotoMat!
Link to post forwarded to Homeland Security.......... :laughing:
So if i'm viewing this correctly, our NZ sparky has upp'd the voltage , and fried both the branch circuit, then feed to the brkr w/o a load....?
Discussion Starter #16
If I heard the vid right he is stepping 380 volts down to 42 volts but with a much higher current (several hundred amps)
I will re-watch the vid.
Basically he is turning the wire into the load, the same thing that would happen with a utility set up involving a short circuit and no breaker, though current here is a tad lower.
Data Tech/Apprentice.
Was that a GE breaker? :whistling2:
I believe the man in the video is from New Zealand.
I cant make up my mind if it was Kiwi or Australian, I was leaning towards Aussie due to the strip connectors he was using. He isnt a native born though I dont think from his accent.
Nope it is NZ from his other videos, well spotted MTW
1 - 19 of 19 Posts
