Status
Not open for further replies.
1 - 10 of 10 Posts
I am replacing receptacles and switches in a remodel. While replacing a 3 way switch I discovered one of the conductors has a slice about 2 inches long down the insulation. I can see copper. There is not enough cable to pull and re-terminate. Its probably been like this since the house was built 25 years ago but I can't leave it. Is it acceptable to repair this by cutting the conductor off where the insulation is good and wire nut a 4 inch length of 14awg to reconnect the switch? Forgive me I do not typically do residential jobs and not familiar with best approach here!
Sounds like a great question to ask a professional electrician.
so what you really mean is you don't do electrical work at all right?
felonious smile.
Strip a piece of #12 red insulation and slide over bad section, tape joint.
Unfortunately it was likely a "professional electrician" that damaged and left it. Thanks for the suggestion though!
Yes... it is acceptable to do what you suggest...but maybe add a couple inches to your 4 so the next guy can pull the device out of the box...
Thanks for posting on ElectricianTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Reactions: randas
1 - 10 of 10 Posts
Status
