The job is to install a box at face level for a wall light on the first floor of an existing, finished home.
The basement has a concrete foundation. On the foundation is an insulated wall with 2x6 vertical lumber, fiberglass insulation and plastic vapor barrier against the drywall. I need to snake a wire up from the basement into the wall to get power to this box.
I can drill into the bottom of the wall from the basement but visibility up the hole is impossible because the wall is set back from the foundation. I doubt that I will be able to locate the hole precisely at the edge of the drywall, but I'll try my best.
How do I get the snake on the drywall side of the insulation & vapor barrier?
Thank you for your help.
Bob
Bob
