1 - 20 of 36 Posts
I own stock in FotoMat!
Do they have to give you a code reference or can they just say "thats how we do it". I normally don't have problems, but this guy is complicated.
The cops just can't pull you over and 'give' you a speeding ticket, can they? No, they must provide you with the law you broke. Inspectors are the same... they are in enforcement. They enforce rules that are enacted into laws. If there's no law against wire nuts in panels (and it ain't in the NEC.....) then they must allow it unless there's a local amendment stating otherwise. And if there's a local amendment, they should be able to provide that to you.
They're INspectors, not EXpectors.
480sparky said:
The cops just can't pull you over and 'give' you a speeding ticket, can they? No, they must provide you with the law you broke. Inspectors are the same... they are in enforcement. They enforce rules that are enacted into laws. If there's no law against wire nuts in panels (and it ain't in the NEC.....) then they must allow it unless there's a local amendment stating otherwise. And if there's a local amendment, they should be able to provide that to you. They're INspectors, not EXpectors.
Nice I like that example.
That depends on what you're joining. I doubt its kodsher (get it?) to use a wire nut on your service wire. Then again, if you have the skill set to put a wire nut that big inside a panel and get the cover on...... Walk away. You've won the game of Sparky.
1 - 20 of 36 Posts
