I have both in my cart.
Okay I did a little research on my own and placed the order just like you posted. Thanks a lot brother. I really appreciate that.![]()
Amazon.com: Lutron Caseta Switch & Remote-Wireless Control | 3-Way Switch | Compatible with Alexa, Apple HomeKit, and the Google Assistant | P-PKG1WS-WH | White : Everything Else
Buy Lutron Caseta Switch & Remote-Wireless Control | 3-Way Switch | Compatible with Alexa, Apple HomeKit, and the Google Assistant | P-PKG1WS-WH | White: Everything Else - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Lutron 3-Button with Raise/Lower Pico Remote for Caseta Wireless Smart Lighting Dimmer Switch, PJ2-3BRL-WH-L01R, White - - Amazon.com
Lutron 3-Button with Raise/Lower Pico Remote for Caseta Wireless Smart Lighting Dimmer Switch, PJ2-3BRL-WH-L01R, White - - Amazon.comwww.amazon.com
One of each of these, and you do not need wifi. You can mount them to the handy boxes.
My wife got me a Dremmel tool last Christmas and I have used it several times since then. Sounds like a plan.Yeah I've often gone to town with the cutting wheel on a dremel.
Thats what I have now. I ran all EMT in my basement with 1900 boxes and raised covers. The damn switch has no break off ears. Its designed for flush mount device that press up against drywall. I checked every GFCI and all square receptacles and switches I have and every single one of them would work. No cutting required. Just snap off ears and some have another snap across the top and bottom of the yoke.
I now envision you as having a pointy beard that stretches all the way down to almost the ground , and you standing with a big Gandalf type walking stick. Mostly because your wife seems to take care of all your errands.......My wife got me a Dremmel tool last Christmas and I have used it several times since then. Sounds like a plan.
Note: She got me a attachment set for the Dremmel. Guess what? The attachment I use the most is not included. The piece that looks like a drill bit but is designed to cut on the side of it. For cutting holes and similar. I think I'm going to tell her to return the kit and buy as many cutting drill bits she can get for about the same price.
Lutron did not consider this in the design.
you talking about an extension ring?Somebody who remembers the model numbers for Raco post a picture of the 4" sq boxes that have a cutout in the back so you can expand outwards from a flush mounted metal box in a wall. Just stick one of them on over the existing box and use a gfi RS cover .
Not a regular extension ring. The knockout is the size of the single gang sw ring, including 2 slots for the existing device threaded holes so you screw the new box to the old one using the old one's holes and 6- 32's.you talking about an extension ring?
sounds very handy, mounted either way possiblyNot a regular extension ring. The knockout is the size of the single gang sw ring, including 2 slots for the existing device threaded holes so you screw the new box to the old one using the old one's holes and 6- 32's.
She does. I haven't been to a store in ages. Grocery store yes as I do all the cooking. But everything else including clothes she gets for me. If can't get it online I usually don't get it.I now envision you as having a pointy beard that stretches all the way down to almost the ground , and you standing with a big Gandalf type walking stick. Mostly because your wife seems to take care of all your errands.......
A good easy idea. I might even have one? ThanksWhy not just a mud ring, get a 5/8 to 1" mud ring and then just install a cover plate over it.
I have a couple of these on my van along with the regular ones, come in handy when needed.Not a regular extension ring. The knockout is the size of the single gang sw ring, including 2 slots for the existing device threaded holes so you screw the new box to the old one using the old one's holes and 6- 32's.
I probably have one in my van as well , but I was being too lazy to go look up the number......I have a couple of these on my van along with the regular ones, come in handy when needed.
