Status
Not open for further replies.
1 - 17 of 17 Posts
I need to wire 110 volt in USA this fan but I'm not sure where connect the black (hot) and the white wire (the ground) There int green wire ground in New York City
I guess from the picture the LINE1 I should connect my black and LINE2 my white. and tape together the ORANGE,BROWN,RED
Thank you for help
CArlo
Discussion Starter #3
I mean my black wire connect to the LINE1(PURPLE), my white (the ground) connect to LINE2 (BLACK,WHITE,YELLOW) and ORANGE,BROWN,RED taped together (none of my wire connect to them
Residential remodeling
Sorry, I misunderstood your thinking. Just remember the orange, brown, and red actually are made up together stripped and wire nutted.
Also, correct terminology for the white line power is neutral. A ground is considered different (green) even though it goes to the same bar in the main panel.
What colors did your Journeyman tell you connect to?
Reactions: Metersocket648
residential, commercial, and industrial
@Kevin , where are you?? We need your expertise
Reactions: Milio9548
Actually the white wire is the "grounded" conductor, and the green is the "grounding" conductor.
The NEC avoided using the word "neutral" until it was finally defined in the 2008 code.
Then there are some people that simply call them positive and negative, rarely have i heard people call the grounded conductor "common"
I jerked off too much, now I can't see wire colors.🤣🤣🤣 Guess I'll need retraining.
🤣🤣🤣now you can pull wire like a mofo with that arm but can't color code worth **** 🤣🤣
Coffee drinking member
I would buy a cup of coffee and pretend the job was done.
Common is a term used on HID ballasts and door bells referring to a terminal that is the same on either/same configurations.
Retired
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to Register
1 - 17 of 17 Posts
Status
