Bingo. 220 ton
It probably is. One of them cross threaded into the piece of junk LBs and I didn't feel like retapping it so I just hammered on the wrench until she stoppedJlarson said:One stub looks a little higher. lol
Cooling off a whole lot of water!Awg-Dawg said:What are you using the chiller for?
Nice job..:thumbsup:Yesterday's project. I wanted to make the rigids shorter but I only had 5' of ltfmc left to work with. It's not my favorite kind of installation but it's done.
Oil separatorsmeadow said:Looks good!:thumbup: Curiosity has me again.:laughing: What are those nichrome coiled resistors for?
Your work looks good. Did you caulk around the penetrations?ponyboy said:Oil separators
I shoved some scrap backer rod around the conduits and then spray foamed from top and bottom. I was a little worried about vibration from when the chiller was running but after I put the strut on the pad and strapped them they are as sturdy as sears.dawgs said:Your work looks good. Did you caulk around the penetrations?
Is it cooling your building or some piece of equipment?Cooling off a whole lot of water!
Nice job pony:thumbsup:I shoved some scrap backer rod around the conduits and then spray foamed from top and bottom. I was a little worried about vibration from when the chiller was running but after I put the strut on the pad and strapped them they are as sturdy as sears.
No ahj here. Those conduits run for another 100' below in EMT. I did rigid stubs because it's easier to spin them into the LBs below rather than messing around with EMT and connectors. Everything we do here is basically a judgement call made by the installer on the fly. Not a ton of plant specs really but once you've been here a while you know what they likechicken steve said:Nice job pony:thumbsup: i'm curious as to those GRC's , we were told by AHJ they needed a 'sleeve' penetrating floors , which we did in sch80, , ran the GRC through, then firecaulked between 80 & GRC. never did get an answer if it was some local thing or not.....:001_huh: ~CS~
