Today's project. 400 amp feeder for the ipac. Set the pull box in the ceiling and cored through the wall last night, concrete pad was cured enough this morning to set gear and finish pipes then the Hoffman cabinet. This was originally supposed to be a panelboard-transformer-panelboard setup but got switched to an ipac after the pour so I rolled with it. In case you're wondering there is no UG entry in an ipac this small, hence the cabinet.
