Would you use a 3 Phase, 3 DIN, RCBO?
  • Yes, 1/yr
    Votes: 0 0.0%
  • Yes, 10/yr
    Votes: 0 0.0%
  • Yes, 100/yr
    Votes: 0 0.0%
  • Yes, 1000/yr
    Votes: 0 0.0%
  • No .. total waste of time ..
    Votes: 0 0.0%
1 - 9 of 9 Posts
Would you use a 3 Phase, 3 DIN, RCBO/GFCI?
Would you use; and do you think there would be much demand for, a 3Phase RCBO (or GFCI as you Americans call them) that takes up only 3 DIN spaces?
To achieve the compact size the neutral is just a feed through and is not switched .. do you percieve that as being a problem?
My friend, an electronic engineer, has designed and patented one and I'm wondering if I should help him commercialise it ...? Is it worth the effort? Is there a need for such a thing?
Any help on this matter is greatly appreciated ..
Is there a market for 3 Phase, 3 DIN, GFCI's ..?
Thanks backstay .. you'd call it a GFCI then?:thumbsup:
I suppose the question still stands .. Would you use a 3 Phase, 3 DIN GFCI? And do you think there would be a significant market for it?
Again thanks for any help given ..
Some spec's ...
Some good info and questions backstay ..
The unit will do upto 32Amps at the moment with 64Amps possible if there is the need.
It is electro-mechanical by design which makes it fairly voltage independant, to a degree, and has been insulation tested to 6kV - which it has passed ..
Buzzy304E
The breakers in our panels are not,by and large, DIN-rail mounted, so I'd say low volume item.
Also,as I understand it,our GFCI's are set to trip at much lower current values than RCD's are. Furthermore, breaker sizes of 32/64/etc., are not standard sizes used here.
Is it an RCBO main?
There isn't going to be a real need for that in the states, stick to your local markets where that type of equipment is used. Less certification and listing costs that way too.
1 - 9 of 9 Posts
