Hello guys! I hope you can help me here, in regards to motor wye-delta starter.
In the motor nameplate: 220 Vac Delta/380Vac Wye 3 phase.
In the electrical panel we have 380Vac 3 phase supply. Upon starting the motor will start in wye connection with 380Vac supply, and then after a few seconds it will shift to Delta connection and continues running on delta connection until the process is done. During in delta connection the supply voltage is 380Vac, but in the motor nameplate the delta connection required 220Vac. how come this possible?
Pls. help me explain this...
Thank you in advance...
