I will preface my questions by admitting I have no experience with a wye start delta run controller or motor.
I've researched quite a bit and I think I have a loose understanding of the concept. The FP controller is using a closed transition between start and run.
Section 430.21(C) seems to say that the motor conductors between the controller and the motor can be sized not less than 72% of the FLA.
I, most likely, am misunderstanding the concept. The best I can tell, there will be 6 conductors from the controller to the motor. One set for start and the other for run.
The questions;
1. When the motor is up to speed will all 6 of the conductors between the controller and the motor be current carrying conductors or will the "start" conductors be removed via a contactor in the controller?
2. If the start conductors are removed via a contactor wouldn't the run conductors then carry the FLA of the motor?
Pete
The questions;
Pete
