1 - 14 of 14 Posts
In the process of roughing in a new construction house and the owner through me a knuckleball I'm trying to figure out. 90% of the time for outside gutter lighting, I'll just run them off a timer. Odd time I'll run a photocell or photocell/timer combo. This customer though wants a photocell to turn on the lights and have them turn off at a predetermined duration like 4 hours. He basically doesn't want to have to remember to adjust the timer every time for the yearly changes in daylight. So this is a first for me so if anyone can recommend any ideas that would be great.
I was told to go with an automation option like x10 stuff but have no experience and not sure it can do what I want. Thanks!
Sent from my Nexus 7 using Tapatalk
Seems the Aube doesn't adjust for daylight savings but intermatic does. Neither have a countdown feature but I'm sure I can convince the customer its not needed. He's pretty stubborn and eccentric so hope this calms him down!! If anyone has any other ideas, please share!
What do you mean by countdown? I've been using that Intermatic timer to control site lighting for a long time.
I have used a timer set to come on in the afternoon and off at the time desired by the customer. A photocell controls the on time.
You end up with on at dusk and off at xx:xx PM
No adjustment necessary unless he wants to change the off time.
Ya I've done that many times and what I offered but instead of xx:xx, he wants x hours once the photocell turns the lights on. Personally, I think its stupid and an astro timer makes more sense so I'll find out tomorrow!
FrunkSlammer said:
You have finally proven yourself knowledgeable and useful! I'll be nice to you all week. I never knew this existed.
Lol I have my moments.
The Aube T1072-3W is one nice timer. Of course it does daylight savings.
Has a great Table (far better then Intermatic for us folks up north) for sunset/sunrise programming. << You can even offset those times if you wish. Example: Customer wants lights on 40 minutes (70 minutes max either way) before sunset.
21 on/ 21 off events per day can be programmed into the unit.
Single pole or 3-way. Does it all. Just learn to program it.
Great device!
Requires a neutral.
1 - 14 of 14 Posts
